MAF ?'s
Old Feb 22, 2005 | 06:05 PM
brownboy2020's Avatar
brownboy2020
Default MAF ?'s
atm i have cai, 70mm tb, and upper / lower intake... is the stock MAF stopping these mods from performing as wel as they should? and also will i feel a big diff i get a 73mm one... thx for the help guys trying to debate between maf or control arms
Old Feb 22, 2005 | 06:07 PM
stanglx2002's Avatar
stanglx2002
Default RE: MAF ?'s
yes it is bc the stock MAF is only 55mm and you need at least a 73mm with that 70mm TB im puttin on a C&L 76mm with my 70mm TB
Old Feb 22, 2005 | 06:17 PM
Green5pt0's Avatar
Green5pt0
Default RE: MAF ?'s
Well the stock MAF isn't helping you any, but its not the real solution. i have 70mm TB and MAF with a trick flower upper and lower intake. i didnt even feel a huge differance with these upgrades because of the stock heads. but in the mean time look for a 70mm MAF from a 93 cobra, it will be much cheaper than an aftermarket one. Just make sure its got the right sampling tube for 19lb. injectors (93' cobras had 24lb) , i got mine on ebay and it had the right tube. works great.
-Green5pt0
[IMG]local://upfiles/12913/4D8D7D1B077441EAAEACB754453587B9.jpg[/IMG]
Old Feb 22, 2005 | 06:22 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: MAF ?'s
why the corbra..it's not interchangable like the c/l...you can get a 76mm c/l used for 75-100 buck...the 70mm T/B is too big a 65mm would be better suited for your car
Old Feb 22, 2005 | 06:40 PM
brownboy2020
Default RE: MAF ?'s
ya i was debatin whether i should have gotten the 65mm or 70mm, but i want to do mods in the future... and w/ the mods i want i dont think a 65mm would be big enough so i just went w/ the 70mm to make it ezier down the road..
Thx for the help guys, im prolly gonna order the C&L 73mm maf, its pretty cheap and ts free shippin$
Old Feb 22, 2005 | 06:44 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: MAF ?'s
think about it... if your maf is smaller than your tb... where do you think your restriction is? what good is having a tb bigger than your maf... its only gonna be able to flow what your maf flows, you always want a bigger maf than tb
Old Feb 25, 2005 | 02:37 AM
brownboy2020
Default RE: MAF ?'s
so im getting the 73mm C&L maf. do i need to keep the screen thats in there or can i take it out?
Jb145700
Aug 21, 2022 06:37 AM
jwog666
Dec 27, 2021 08:09 PM
piotrek53
Oct 13, 2015 06:54 PM
mltdwn12
Sep 23, 2015 08:54 AM
stangin1996gt
Sep 21, 2015 11:01 AM
