coil over suspension
hey all, im in desperate need of new shocks and struts and im going to replace my a-arms with some tubular ones and i was thinking of just getting the d and d coil over set up for the front and back. my concern is that the new springs for the coil overs will hit my wheels and tires. i have 9" rims with 245's in the front and 275's in the back. anyone with any experience with this?mytires are awfully closeto the shocksand struts now. almost to close for comfort.thanks
RE: coil over suspension
depends on back spacing...it may clear it may not..you'll just have to try it..I have the D&D SET UP ON THE FRONT OF MT CAR FROM K-MEMBER TO a-arms to coil overs and it worked awesome......but I run skinnies on the front too!!
and if it helps, they are 04 cobra wheels, the car is an 85 gt with an 8.8, no quad shocks, upr extreme duty upper and lower control arms and the front has 95 gt spindles and breaks.
you probably better find someone with a fox with the coil overs on it before you go spending your money on them. If you know someone, try putting your rims on their car. they should fit though considering that they are all the same platform...............
Matt's 95 Stang
10-05-2015 07:16 AM
