gauge cluster speedo funny
RE: gauge cluster speedo funny
no just do the necessary work to remove the cluster from the dash and then remove the plastic clear lense = 4 screws I believe then pull out the speedo part and replace and reinstall in reverse order
I think it took like 45 minutes for me, to do the entire housing you just remove the headlight switch and hazard switch, then that piece of trim(4 screws I think). Then 4 screws like he said to remove the instrument cluster. Then reach behind it and d/c the speedo cable, pull it out of the grommet. Undo the retainers(2) and use an 11mm wrench to take the hold down off the side of the transmission.
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
Matt's 95 Stang
10-05-2015 07:16 AM
