TPS voltage question again!
ok iv read through a million posts on the theory of adjusting the tps voltage. and i cant seem to find a straight answer or what the final verdict is.
heres my take on it.
i have idle issues with my engine. ive done all the adjustments and cleanings that most people advise, however when i check the voltage of the tps sensor wires the red and green both read about 5.0 volts. or slightly more. i tried turning the sensor but nothing changes.
why would both wires read 5volts? or is it possible i have a bad sensor?
RE: TPS voltage question again!
The .9999 vdc TPS adjustment is a myth, as long as the volatge is between .5 - 1.19 vdc (.7 - 1.0 vdc is optimum), the computer will do the rest. In your case, looks like that TPS is fubar'ed....... suggest to run a DIY KOEO/KOER/Cylinder Balance Self-Test to check the system though.
ok good info, ill read through it, do some tests and stang8689 ill keep you posted if i need it.
i hope i can do this, my car isnt exactly simple to work on. 67 fastback with 5.0 fuel injected motor with painless wireing harness tied into stock wiring. its like a huge jigsaw puzzle. especially i didnt put it together.
replace the sensor, it is a variable resistor, that should cut the 5.0 volts down to .99-1.03 volts, key on engine off.
positve -green wire negative black wire.
If a new one does the same, the ECM is shot.
ORIGINAL: djsprinklesnjo
holy crap i cant make heads or tails out of that article. seems very advanced.
1. Having to set the TPS to .999 vdc is [sm=bs.gif] information.
2. If the TPS voltage is between .5 vdc and 1.19 vdc, and no TPS related failure codes are logged in the ECM = system is OK.
3. There is a computer in the EFI system that takes care of all the system sensors variability and filters their input.
4. In your case...... replace the sensor and recheck the system.
jwog666
12-27-2021 08:09 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
