5.0 Nitrous Motor Write Up????
I just wondering if anyone on here had a good website or link for a 302 5.0 Motor Build??? Would be greatly appreciated if you would post them. I'm considering buying a 5.0 302 for my 1985 Drag Ranger I was kind of leaning towards nitrous or a turbo setup. Thanks.
RE: 5.0 Nitrous Motor Write Up????
If you want to spray then use a decent block.... Ispray and on just the motor I had a fairly stout build and sprayed a 100 shot and now I'm loosing oil pressure at hot idle = down to 10 psi and on a rev it'll go up to 35 max and drop off quick to 10 psi......It's quite possible I may have cracked the block under the crank up to the cam bearing oil gallies[:@]...I'll know for sure by tommorrow evening.....but my point is if you plan to spray on top of a well built motor start with a good foundation and sturdy block
ORIGINAL: mjr46
good point make sure your motor is up to the job and added pressure if u do all the do's u should be fine my new motor will be my first nos car/motor of my own
Will I was wondering what type of block and rotating assembly I should run for a 150-300 shot of nitrous?? Also what type of heads and intake too??? Looking for a low budget build. Was thinking of a 347 Stroker. . . ? But what type of components should I run?
ORIGINAL: nathansee3
jaiidutch
09-14-2015 10:29 AM
