Your thoughts on motor
I need a motor for my 93 but I don't know much about these cars yet. Can you tell me if this seems like a good deal?
Brand New Rebuild 5.0 306 Ford Mustang GT Engine - $1000 [hr]
THERMAL CLEAN BLOCK
BORE & HONE W/TOURQUE PLATE
INSTALLED FREEZE PLUGS
INSTALLED CAM BEARINGS
R&R PISTONS W/PRESS PINS
POLISHED AND MICRO-POLISHED CRANKSHAFT
EXTERNAL BALANCE CRANKSHAFT
SEALED POWER SBF .040 HYPEREUTECTIC PISTON SET
SEALED POWER SBF .040 STANDARD RING SET
CHEV. V6 200-229 PERFORMANCE ROD BEARING
302 MAIN BEARINGS
SBF STANDARD CAM BEARINGS
SBF BRASS FREEZE PLUGS
302 HIGH VOLUME PUMP
SBF FRONT COVER GASKET
SBF302 ONE PIECE OIL PAN GASKET
SBF302 ONE PIECE REAR MAIN
ARP SBF302 OIL PUMP DRIVESHAFT
COMP SBF 5.0L DOUBLE ROLLER TIMING CHAIN
MOTORSPORT SBF HYDRAULIC ROLLER CAMSHAFT E-303
THE ENGINE ALSO HAS A 300$ CANTON OIL PAN. I DO HAVE THE ORIGINAL PARTS INCLUDED IN THE PRICE.I MAKE SURE IT IS ALWAYS LUBED PROPERLY AND THE PISTONS ARE TURNED FREQUENTLY.IT IS KEPT INDOORS AT ALL TIME.NO RUSTING OR OXIDATION HAS OCCURRED. THIS ENGINE HAS A 10:1 COMPRESSION RATIO.
THERMAL CLEAN BLOCK
302 MAIN BEARINGS
LivingInThePast
09-16-2015 12:20 PM
jaiidutch
09-14-2015 10:29 AM
