performance question
Old Nov 4, 2007 | 05:58 PM
F5GTS331's Avatar
F5GTS331
Default performance question
how well do you think a 94 gt with a cai, 65mm t body, ported intake, tfs stage one cam, cobra rockers, march pullies, msd ignition, jms chip. and a 3.55 gear should run?
Old Nov 4, 2007 | 06:21 PM
bertt's Avatar
bertt
Default RE: performance question
high 13's? maybe low 14's? i dont really know
Old Nov 4, 2007 | 08:41 PM
94RedDevil's Avatar
94RedDevil
I would think that with the 'good driver' mod (one that i'm working on accomplishing) you might be mid to high 13's
Old Nov 4, 2007 | 08:46 PM
ctgreddy's Avatar
ctgreddy
im gonna guess low 14's maybe.
not really sure but i know from ur list u still have the god awful e7 heads holding u back big time.
the gears where prolly what helped the most out of all that.
Old Nov 4, 2007 | 09:37 PM
87gt5speed's Avatar
87gt5speed
14.2 to 13.8 if your a good driver.
Old Nov 6, 2007 | 07:42 AM
F5GTS331's Avatar
F5GTS331
actually the cam is what helped me most out of all of that. installing it alone brought it up from when it was bone stock from 16.4 to 15.1 then from there all i got out of doing the rest was a 14.7 so i'm like wtf is holding me back here? ive done all this other stuff and only get four tenths out of it?
Old Nov 6, 2007 | 10:53 AM
91hatchgt's Avatar
91hatchgt
Yep, you can only do so much with the E7 heads.
BTW: What is the elevation at, at your track? Mine is at appx. 3000 ft. and I ran 14.8 bone stock in my 94.
Old Nov 6, 2007 | 11:34 AM
Stroked91's Avatar
Stroked91
i seen a notch run a 12.3 with stock cam and ported e7s. weight can affect your time as well
Old Nov 6, 2007 | 11:53 AM
F5GTS331's Avatar
F5GTS331
not sure what elevation is but i'm gonna look it up. it was in bowling green kentucky where i ran the car at if that helps anything
Old Nov 6, 2007 | 11:56 AM
F5GTS331's Avatar
F5GTS331
true weight does affect, but a notch is only 500 lbs lighter which is about .5 in a quarter. numbers still not adding up. i'm sure stock heads have a lot to do with it too, but as 91hatchgt said he ran a 14.8 bone stock in the same style car
