Cam clearance
Yeah, alphabet soup isn't the best way to go. Old single pattern cam that hasn't been changed in what, 15 years? There are better cams out there. I'm running a grind from Crane that's a 1.7rr Cobra replacement cam and it has a CARB EO# if you need to pass emissions. You'll make better power with a better cam, but in the end it depends on how the whole engine is built up. What's been done to the heads? What's compression at? Internals, intake, exhaust etc etc. What gears do you have? That's gonna impact what cam you want
it wont damage it when ur turnin it over by hand because if there was a serious problem and the valve will obviously hit the piston, you wont be able to turn it over. you want like a minimum of like .100" or somethin?
some body correct this if im wrong since i probably am[:@]. but when ur checkin the clearance and turnin it over, you have to use a solid lifter since the hydraulic will collapse slightly causing it to not give a correct reading
depending on the heads you have, if its a cobra i know for a fact you cant run a f303, wich has 1.7 rockers but being gt40 heads the valves are bigger and wont clear, on a regular gt its close for the f303, mine held a f303 fine, mines a 95 model...i have had friends that try to run a f303 and it worked ok for them too...
ORIGINAL: cleanfitty
By tis time wouldn't the damage be done if there were going to be some interference???
ORIGINAL: mjr46
set up your valvetrain and turn the motor over 2 times by hand
ORIGINAL: SuperFox88
I made 234 rwhp on a stock motor, stock heads, and a stock cam. I am gonna use the stock heads, just cause it is the way i wanna go. I am wanna go with the 1.7's. I've ran my hole setup idea through a bunch of people and they all say it will work.
[align=left] [/align]
I'll just not worry about it and go with the E cam and 1.7's
[sm=chairshot.gif]you still need to check ptv and set up the valvetrain geometry correctly by measuring for proper length push rods and all
...you have alot to learn...(shyt, so do i... but here....)
answer a few questions for me
whats lift with 1.6s? now what is it w. 1.7s? e cam
how about the f cam w. 1.6s?
are you replacing the lifters?
your getting RRs it sound like, how do u plan on setting them up?
whats the length of ur pushrods now? how will you go about checking and making sure ur using the right size?
see the thng that makes cam's a lil more complicated is that what works for one set up, wont work for another, stock **** is not consistant... and when you think about it... your going from .444 to .512(f w. 1.6s) in lift, doesnt look like alot, i mean **** its less then .1 of an inch... but it makes a huge differance, and can cause all sorts of problems
bottom line, look into this process more...
