Diff Play
Old Nov 8, 2007 | 07:50 PM
Ketis's Avatar
Ketis
Default Diff Play
well my car makes this clunking sound now and it does it when i drive
so i got under neath it and the rear end clunks when i turn the wheels
then i started moving the driveshaft and it clunks
i believe that its the u-joint and bearing in the differential
does anyone have any other ideas?
or is there a good writeup on how to change the bearing?
Old Nov 8, 2007 | 08:18 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: diff play
Take the drive shaft out, and check the joints for play, first and foremost. It might just be that simple.
On a side note, your sig is too big. 500x250 is our allowable size.
Thanks and welcome to our forum.
Old Nov 9, 2007 | 11:52 AM
Ketis's Avatar
Ketis
alright, so i took off the driveshaft today. The disc that the driveshaft bolts to has alot of play in it. i dont think that it is normal. i can move it about 15-20 degrees before it engages the rear wheels. and when i turn the disc its easy to turn but in a certain spot it gets a little difficult then it goes easy again like there is something binding.
any ideas would be appreciated
Old Nov 9, 2007 | 04:24 PM
Ketis's Avatar
Ketis
i could really use some opinions on what could be wrong
because ive looked at it and i really cant quite pinpoint it.
lincolnshibuya
Dec 8, 2020 01:49 PM
67LimeCoupe
Sep 30, 2015 04:46 PM
Ghost_Conscience
Sep 23, 2015 02:17 PM
gagemcc
Sep 22, 2015 09:43 AM
