MSD Distributor ?
MSD Distributor ?
How do I tell if I have an iron gear or steel gear? I bought a new Billet Steel MSD distributor 8582 I think. I have a roller cam and I know if I use an iron gear the cam will shred it.
RE: MSD Distributor ?
I think it is iron, but MSD should be able to confirm. I heard you may want to use a bronze gear for a roller cam? It may depend on the lift though. The cam supplier should be able to answer that better.
DISTRIBUTOR GEARS
A distributor’s performance is only as good as its drive gear. MSD Ignition has put a great deal of effort into researching and testing a variety of metallurgical compositions, heat treating and coatings to provide you with a durable, accurate and strong distributor gear.
MSD engineers have built test fixtures and spent hundreds of hours testing and evaluating the metallurgy of our gears. The result is a special alloy iron gear that is treated to a low friction coating process. To you this means long life, an easy break-in period and reliable performance!
Iron Gears
* Increased outer hardened layer thickness (RC 55-60).
* Micro polished surface for smooth contact.
* Proprietary formulated ductile iron.
* Melonite QPQ coated reduces friction and initial wear.
* Interstitial carbide concentration improves wear resistance and running properties.
Iron Chevy Gear, .500" ID PN 8531
Iron Chevy Gear, .500" ID,
Oversize 0.006†OD PN 8532
Iron Gear, Ford 351W, .531" ID PN 85852
Iron Gear, Ford 289, 302, .468" ID PN 85832
Iron Gear, Ford 351C, 351M,
400, 429, 460, FE, .531" ID PN 85812
NOTE: Some Ford Gears do not have roll pin holes.
Special Ford Applications:
There are different versions of the Ford 302 engine that may require a special gear. The 302 engines with a roller camshaft require a special steel gear.
Non-EFI 302 with Roller Cam, 0.468†ID PN 85833
EFI 302 with Roller Cam, replacement for MSD PN 8455 and 8456
MSD 351W Distributors, 0.531†shaft PN 85834
Bronze Gears
MSD Bronze Distributor gears are machined from quality AMPCO 45 aluminum bronze containing 5% nickel. This special combination creates high strength gear teeth that are less prone to wear even with high volume oil pumps.
Gear, Chevy .500" ID PN 8471
Gear, Pontiac V8, .500" ID PN 85631
Gear, Oldsmobile V8, .500" ID PN 85661
Gear, Ford 289, 302, .466" ID PN 8583
Gear, Ford 351C, 351M, 400, 429, 460, FE, .530" ID PN 8581
Gear, Ford 351W, .530" ID PN 8585
Gear, AMC V8
Gear, Chrysler R5 PN 8252
Bronze Oversized Gears
Absolute timing accuracy cannot be achieved until every mechanical detail is handled. MSD’s new bronze oversized gears help obtain perfect timing by meshing to the camshaft gear properly.
MSD Chevrolet Distributors
+0.006†PN 8472
+0.009†PN 84722
+0.012†PN 84723
+0.015†PN 84724
Iron Gears
Bronze Gears
Gear, AMC V8
+0.006†PN 8472
+0.009†PN 84722
+0.012†PN 84723
+0.015†PN 84724
ORIGINAL: 5.0mustang5speed
what does lift have to do with dis gears? nothing..wtf..
That's wtf bart butt...show a little respect for basic physics.
ORIGINAL: Wessy
So is the bronze stronger than the steel? My local speed shop only sells the steel gear for chevy's or the bronze for ford.
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
