heads
Old Nov 30, 2007 | 02:05 PM
1990mustanglx's Avatar
1990mustanglx
Default heads
so ive decided to go with the patriot aluminum heads unless you guys persuade me other wise. does anyone know how much more horse i should expect? and also if io get the heads do i just bolt on and go? or what do i need to instal them the right way so my car will runs right? also im going to get a cam i was thinking e or f cam, but also the trickflow track heat cam but then its got all this lift crap i have no idea about.
Old Nov 30, 2007 | 04:34 PM
Mustangkiler's Avatar
Mustangkiler
Default RE: heads
if your using stock pistons then you will need to notch em with patriot heads, also the only trickflow cam you can run without notching is the stage 1.
Old Nov 30, 2007 | 04:43 PM
1990mustanglx
Default RE: heads
can you explain what notching them means? if i just get an upper and lower intake a cam and some injectors with mass air meter will i notice a big difference?
i was thinking the e303 cam or f cam, 24 pound injectors with 70mm mass air and a trickflow upper and lower or typhoon
Old Nov 30, 2007 | 05:40 PM
tinman's Avatar
tinman
Default RE: heads
That 'lift crap' that you post about is very important to make a SBF run good.
You probably need to go onto Comp Cams site and study some about camshaft selection..........
Old Nov 30, 2007 | 06:07 PM
Mustangkiler
Default RE: heads
means you need to get a special tool and cut into your pistons to make sure the valves dont hit them since the patriot heads have 2.02 intake valves.
Old Nov 30, 2007 | 10:50 PM
OnyxCobra's Avatar
OnyxCobra
Default RE: heads
If you don't want to notch your pistons there are plenty of other head choices you'd probably be happy with.
Old Dec 1, 2007 | 02:15 AM
xxxmustangtxhc's Avatar
xxxmustangtxhc
Default RE: heads
if you have the time and money notch your pistons and graba trick flow stage 2 cam along with 1.7 rollerrockers on the exhast side and 1.6 on the intake. also star off with a cobra or a typhoon intake along with push rods fms lifters and 24 lbs injectors and you will fiil the differance.
Old Dec 1, 2007 | 08:51 AM
my77stang's Avatar
my77stang
Default RE: heads
spending money on lifters is a waste, disassemble and clean you old ones - its what major reman companies do[8D]
Old Dec 1, 2007 | 03:07 PM
xxxmustangtxhc
Default RE: heads
if your trying to go over 400 hp get lifters!!!! you dont want a busted lifter as a problem!
Old Dec 1, 2007 | 03:41 PM
gspfunk's Avatar
gspfunk
Default RE: heads
I agree w/ Tinman; you should definitely go do a little research so that you know what you're looking for and dealing with.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
mustangheaven
Oct 7, 2015 10:23 AM
Drastang
Sep 30, 2015 03:48 AM
