Axle Swap
Axle Swap
What is involved in doing an axle swap? As in what new parts besides the axles are necessary, ie. seals, retainer clips. I'm going to be putting in some five lug axles and I'm not sure what I will need to buy besides the axles and how difficult the job is as I've never worked on a rear-end before.
Thanks,
Brian
Thanks,
Brian
RE: Axle Swap
All you need is axles, 3 quarts of gear lube (takes 2.5) and friction modifier (one bottle for the positraction).
Unbolt the cover, drain the fluid, remove the bolt holding the differential pin in place and push in the axles and the c clips will fall out.
Installation is the reverse of removal.
Not a hard job at all.
Matt's 95 Stang
10-05-2015 07:16 AM
KingRando
10-02-2015 08:06 AM
09-24-2015 09:18 PM
