Trickflow Cam. What gear?
Hi i have a trickflow stage 1 cam, and my distributor is an Accel, but recentlythe distributor gear mashed like 4 teeth.
before i had a flat tappet cam with this dizzy.
i think the gear messed up when i change from flat tappet to hydro.
what gear should i get for my accel ( carb) dizzy , to match the trickflow stage 1 cam
RE: Trickflow Cam. What gear?
if you had a roller cam mated to a cast iron gear then yes..it need s a steel gear
http://store.summitracing.com/partde...p;autoview=sku
you'll need to make sure that the shaft diameter is the correct size...but this is the one I used for my 85...you'll have to drill a hole for the roll pin to slide into both sides
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
