Heating?
Old 12-23-2007, 01:58 PM
sofob0909
sofob0909's Avatar
Default Heating?
Is it normal for fox bodies to heat up at traffic lights, Driving my 88 gt hatch i noticed that at lights or in traffic the cars temp rises, Driving it is level but it climbs quickly at stop. Is this normal. I dont want to over heat in traffic. Its a DD
sofob0909 is offline
Old 12-23-2007, 02:02 PM
HACKGT350
HACKGT350's Avatar
Default RE: Heating?
no its not normal for that to happen. do you have an electric fan have you checked your fluid level?
HACKGT350 is offline
Old 12-23-2007, 02:03 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
No, it's not normal. There is a flow problem. Things to check
no debris in front of the rad
fan clutch operating correctly
The radiator could be clogged
T-stat partially closed
PRO50SC is offline
Old 12-24-2007, 06:58 AM
sofob0909
sofob0909's Avatar
bump
[align=left] [/align]
Old 12-24-2007, 08:08 AM
92cobra
92cobra's Avatar
you bump a thread but yet dont answer any of the questions.....right, ok sooo how are we supposed to help you if you dont fill us in.
To answer your question in general NO it is NOT normal for a stang to heat up in traffic/idle/stop etc. Is ther clutch fan / electric fan working/on? Is your coolant level low? Is your radiator clogged? Try turning on your heat, and see if it blows hot. Good luck, Merry Christmas Eve.
92cobra is offline
Old 12-24-2007, 10:08 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check your fan clutch and how far does the gauge climb up too????
mjr46 is offline
Old 12-27-2007, 10:19 AM
sofob0909
sofob0909's Avatar
i bumped to get some more people's advice. sorry, Ill check the coolant level. How do i check the fan, t-stat, or clogged radiator?
Old 12-27-2007, 01:07 PM
sofob0909
sofob0909's Avatar
i put some 50:50 in there. I couldnt see any in the overflow. It seems to have done it. It warms up and i let it sit for a good 5 min and it stayed almost level. It was a little higher but much better. Thanks Guys.
Old 12-27-2007, 02:04 PM
HACKGT350
HACKGT350's Avatar
that should be good anything like that power steering making noise or engine temp a little high check your fluids before anything.
Old 12-27-2007, 09:52 PM
sofob0909
sofob0909's Avatar
the heater doesnt seem to work. I tried it and the air was not hot or cold.
PaulH2
20
01-31-2016 09:48 AM
Explosive
10-02-2015 07:45 AM
folivier
10-02-2015 05:34 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Art161
09-09-2015 10:33 AM
Quick Reply: Heating?
