Insane Wheel hop.!! plz help
Old 01-01-2008, 09:54 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Insane Wheel hop.!! plz help
comp engeneering sells an adjustable pinion snubber...I put one on mine and it works well also as the suspension loads up the rear will rotate up and could be changing the pinion angle like pro50sc says...check that and if you have adjustable control arms....you need to set them accordingly..and removing the quad shocks won't cause the wheel hop....been there done that and have no issues.....but pinion angle will
mjr46 is offline
Old 01-02-2008, 09:57 AM
Ze2222
Ze2222's Avatar
K thx for the hlp guys .. I'll definately look into pinion angle.. what should the angle be at? or optimal angle?
Ze2222 is offline
Old 01-04-2008, 01:46 AM
Ze2222
Ze2222's Avatar
K guys i went and measure pinion angle.. Now my question to u , what should it be at? Also when u launch hard ur pinion angle obviously changes. What is the best angle to have ?
Any help would be nice thx for the great suggestions so far
Ze2222 is offline
Old 01-04-2008, 02:07 AM
Ze2222
Ze2222's Avatar
K from readin previous posts about pinion angle.. I have come to the clusion that the best / optium angle u want when launchin hard is basically straight line.. 0 degrees but that is hard to get...
My question is, how much does ur diff raise upon a hard launch... ?? and why is that if u have the spherical joints instead of poly bushings that it doesn't lift as much..?? Sry kinda new to performance stuff , lets just say i'm in the learning curve.
Ze2222 is offline
Old 01-04-2008, 02:17 AM
w8less
w8less's Avatar
http://baselinesuspensions.com/info/pinionangle.htm
http://baselinesuspensions.com/info/cg.htm
http://baselinesuspensions.com/info/...A_Drag_Car.htm
w8less is offline
jwog666
12-27-2021 08:09 PM
UrS4
10-03-2015 06:23 AM
mungodrums
09-28-2015 10:54 PM
folivier
09-26-2015 02:28 PM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Insane Wheel hop.!! plz help
