Bad Computer?
Old 01-14-2008, 07:13 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Bad Computer?
then do as this link by Joel 5.0 says....even though the computer scanner you bought says it'll work ..often more than not the universal tool won't work on all makes and models
http://myshifter.com/joel50/EECTEST.html
mjr46 is offline
Old 01-14-2008, 07:54 AM
Joel5.0
Joel5.0's Avatar
On a detail note...... "Yes I performed the KOEO test two things that came up as a potential problem one caused by the MAF which has just been replaced" .... if the MAF failure code is still logged as a "hard failure" (code 66, 56)..... the KOER will not be initialized. This will unfortunately mean that the replacement of the MAF was not required to solve the MAF code. Suggest to clear codes and check what shows up in a KOEO.
Joel5.0 is offline
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Bad Computer?
