ingnition coil problem
my car has recently been idleing terrible as if it was largley cammed. i had to keep it above idle for say 2 minutes until it idiled and ran good it ran like it had a miss. well on my way to work i lost all power no throttle. i tried starting it and it just turns over and over no chance of starting. is this my coil? i also couldnt hear my fuel pump kick on the relay works when u turn the key but i didnt hear the wine could that be a problem as well?
RE: ingnition coil problem
its a start theres alot of things it could be coild tip of the iceberg have you tryed to get spark out of it yet if not try have the modual on the distributor checked and i really dont know bout the fule pump
you need to check for spark via spark checker..then check for fuel via a pressure gauge...if you have no spark then troubleshoot the ignition system....check coil..check cap rotor, wires and pick up in dizzy and tfi module
musnicki
09-23-2015 07:11 AM
