codes...
Old Mar 24, 2005 | 05:00 PM
90Mustangfan's Avatar
90Mustangfan
I ♥ Acer
Default codes...
I messed with the egr because it said it wasnt opeing, well the egr holds pressure and opens and closes just right.But I did the tests again and got a code 24 on the koeo test, what is code 24, and whats code 33, I always get those 2 codes.
Old Mar 24, 2005 | 05:15 PM
roundman's Avatar
roundman
Default RE: codes...
33 means the EGR valve opening is not detected. try disconnecting the negative battery cable for a few minutes and then see if this clears this code since you say the EGR valve is moving now.
code 24 is "ACT or VAT input out of self-test range." ACT = air charge temperature VAT = vane air temperature sensor
Old Mar 24, 2005 | 08:04 PM
90Mustangfan
I ♥ Acer
I always get code 33, but Ive only got code 24 1 time and then Its not there, can this test make mistakes. what out of self test range, because I got a new ECT sensor and it says its out of self test range? whats that mean?
Old Mar 25, 2005 | 02:44 PM
roundman's Avatar
roundman
could be the sensor is bad, I don't really know for sure. I think out of range means the voltage signal is either not coming in or is too high or too low for the ECU to recognize it as a good signal.
colschw
Aug 16, 2014 09:12 PM
antnvlz1294
Jan 5, 2014 11:53 PM
jawknee5
Oct 27, 2012 01:35 PM
Bowtietraitor
Dec 16, 2010 08:56 PM
Fifthwind
Oct 26, 2010 07:42 PM
