390 engin into 1990 5.0??
#31
RE: 390 engin into 1990 5.0??
83GT, im sorry bub - but when you want low end *** ripping power for 4x4's, large trucks, or anything else that needs real grunt you DONT use a 302.
you use a 300 I6, a 351, a 460, 360 or 360. you DONT use a 302 (or 289 for that matter)
and btw, modular motors are f*cking worthless. 4v this, add a blower that, blah blah blah. the bore spacing too tight and the bores are too small. not to mention the bicycle chains they have running the cam gears.
#32
With what I've been reading about the new Kaase 428 hemi heads coming out soon, I have a feeling we will be seeing some serious speed out of some cars, I think in a stroked 460 stock block on pump gas it did 901 hp.....thats getting it done.
Matt
Matt
#33
I tell you what, being the owner of a 390 69 torino, I can tell you the gobs of torque at the low end is great, but it dont like to be spun past 6 at all, which is perfect for the street. the problem becomes mods. the only aluminum heads othre than the edelcrap are blue thunder, and they get quite expensive. I can tell you that a nice solid cam goes a looooong way for these motors. the power is not necessarily what these motors were made for, more for torque. if you get the C1 heads I believe, someone correct me if wrong, the ones of the 61 390's and a nice solid cam on an intake to match andsome decent compression, stock is 10 or soto 1 so 11.5-12 to 1which is still pump you will have a NASTY motor on ur hands.. good luck. it will be expensive.
ORIGINAL: abrahney
does anyone know if a 390 will fit into a 1990 5.0...thanks!
#34
ORIGINAL: irish1
Matt
Matt
http://en.wikipedia.org/wiki/Ford_385_engine
The FE was introduced in 1958 as 332 and 352 displacements. They grew into 360, 361, 390, 391, 406, 410, 427 and 428s.
http://en.wikipedia.org/wiki/Ford_fe_engine
#35
370 and 429 truck motors are not 385 Series.
429/460 are 385 series as is the 514 SVO engine.
I think you can run a 390 manual flywheel on a 460, but that's about it as far as interchangeability except for Ford Blue paint .
FE stands for Ford Edsel which they were introduced for. A Larger, better version of the Y-block 272,292,312.
Fitment and exhaust will be the main problem. There are many 460 motor mount kits and headers available for the swap, but nothing I have seen for a FE engine in a fox body. I'm sure with a motor plate it could be mounted and someone like Kooks headers could probably cusom make a set of headers.
