Hard Clutch
Old 01-23-2008, 07:29 PM
toofst4u666
toofst4u666's Avatar
Default Hard Clutch
my 85 gt's clutch pedal is really hard to push ive been fixing the car up for awhile and i havnt driven i much so it got overlooked but its almost painful to drive it this way is there any way i can soften this thing up because its killing my knee to drive it like this??
toofst4u666 is offline
Old 01-23-2008, 07:41 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Hard Clutch
Well, it's most likelya cable or pressure plate problem
PRO50SC is offline
Old 01-23-2008, 07:44 PM
1991LX5.0
1991LX5.0's Avatar
are you sure its properly adjusted? did you try grease on the clutch cable?
1991LX5.0 is offline
Old 01-23-2008, 07:49 PM
fourfivefour
fourfivefour's Avatar
What clutch do you have? Some are harder to push in than others.
fourfivefour is offline
Old 01-23-2008, 07:57 PM
toofst4u666
i dont know what kind of clutch is in it probably the stock one could i jus get an adjustable cable and quadrent kit would that fix it?
Old 01-23-2008, 08:04 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
That would depend on if it's the cable or the pressure plate. How many miles and has it been sitting a while?
PRO50SC is offline
Old 01-23-2008, 09:54 PM
fourfivefour
ORIGINAL: toofst4u666
If you still have the stock plastic garbage it sure as he77 wont hurt. Disconnect your clutch cable and work it back and forth to see if it binds. If the car has been sitting the cable may be frozen.
Also another possibility may beyour throw out bearing may be binding on the grooved up throw out bearing retainer.
Old 01-24-2008, 10:00 AM
Jfsram
Jfsram's Avatar
I don't know how or why but new clutch's seem to be easier to push that old ones. That is when replacing the old one with a same one. Old King Cobra to new King Cobra, stock to stock and even seen this on other cars like fwd's etc.
I think it may be the leverage increasing on the fingers as the pressure plate gets closer to the flywheel. Or the finger pivot points, the fork etc loose their lubrication.
Another time on my 93 LX. I removed a perfectly good appearing cable to lube up, just as maintenance. It felt nice and looked great but the casing had some ugliness due to being close to my long tube headers.
I ended up replacing it with a new one and it felt like the pressure plate was a couple hundred pounds less.
If you need a number to put on that. My 2300lbs plate felt like 2500lbs, after the new cable the 2300lbs piece felt like 2300lbs.
Jfsram is offline
Thunderball
15
11-22-2015 11:49 PM
UrS4
10-03-2015 06:23 AM
guitarman376
09-30-2015 05:54 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: Hard Clutch
