Crank issues
Crank issues
hey everyone, as some of you know im haveing a lot of trouble with my car, i have a vibration and i can not find it, i have replaced sensors cleand maf,iac all that **** and nothing helps, i pulled the heads and had a slight leak, so i surfaced them and put them back on, now i put it back togeather and my headers turn red, and i still have the same vibration, dose anyone think my crank could be bent?
RE: Crank issues
it dose it all the time, it is a automatic, i bought the car like it is i figured i could fix the problem easy but its becoming a pain in my ***, at idle like 650 it is smooth not really smooth but it is ok, at 900-1200 is really rough at 4grand it vibrates a good bit, but it smooths out as the rpms go higher but the vibration gets faster, it never goes away thoe
RE: Crank issues
check the balancer, they are bad about slipping. the balancer is made of two metal pieces with rubber in between and sometimes the outer ring slips and knocks the balancer out of balance.
Ghost_Conscience
09-23-2015 02:17 PM
