Question on vacuum tree.
Old 03-31-2005, 04:13 AM
Dbeck002
I ♥ Acer
Dbeck002's Avatar
Default Question on vacuum tree.
The vacuum tree that is on the passenger side, that has 5 holes. i plugged up 4 of them which were EGR n ****, there is one more that leads to the manifold. can i plug this line up, what is it for?
Dbeck002 is offline
Old 03-31-2005, 04:21 AM
luckythirteen13
luckythirteen13's Avatar
Default RE: Question on vacuum tree.
why are you plugging all you vacuum lines?
luckythirteen13 is offline
Old 03-31-2005, 04:50 AM
Dbeck002
I ♥ Acer
Dbeck002's Avatar
on that 5 hole vacuum tree. one hole isnt used i think, and 3 are for EGR. those are all plugged. there is one more line leading from that tree to the manifold, i wanted to know what its for.
Dbeck002 is offline
Old 03-31-2005, 07:20 AM
92BOOSTED
92BOOSTED's Avatar
If i remember right ,only two of mine are being used from there. One is going to the EGR and the other is going to the fuel regulater.
Rye
92BOOSTED is offline
Old 03-31-2005, 10:39 AM
86HOGT
86HOGT's Avatar
One may be for your heater/A/C controls, but I think mine was on the driver side tree.
86HOGT is offline
Old 03-31-2005, 12:39 PM
link1235jeff
link1235jeff's Avatar
ya two of them go to the smog pump. 1 goes to back of the engine then 1 to the egr
link1235jeff is offline
Old 03-31-2005, 03:48 PM
roundman
roundman's Avatar
ORIGINAL: Dbeck002
not positive without a pic but that should be the line supplying the vacuum to the tree! if you've eliminated the other lines from being used, then you don't need this one either.
roundman is offline
Old 03-31-2005, 04:33 PM
87 hatch
87 hatch's Avatar
my 87 had a break in the vacuum line going to the under side of the intake manifold and my car was running like ****. as soon as i took off the upper intake manifold and fixed the hose my car ran perfect. if im thinking of the same one that you are this is the main vacuum line and if you plug it you car will probly run like ****.
87 hatch is offline
Old 03-31-2005, 05:14 PM
Dbeck002
I ♥ Acer
Dbeck002's Avatar
its just the plastic tree on the passenger side. and the one line that runs to the manifold is small and looks like it has no purpose, not sure. ill try and plug it and see what happens.
Dbeck002 is offline
Old 03-31-2005, 06:03 PM
Tims 88GT
Tims 88GT's Avatar
i know what you mean, i dont think it would hurt anything if you pluged them, one goes to the intake, one to the egr and 2 to the smog pump
Tims 88GT is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
UrS4
09-30-2015 10:13 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Question on vacuum tree.
