sputtering after like 4500 rpms
Old Feb 20, 2008 | 10:20 PM
gtordie's Avatar
gtordie
I ♥ Acer
Default sputtering after like 4500 rpms
i have a 94 gt and if i take off hard, when i get to 4500 rpm it sputters when it is in gear but when it is just reving it will go all the way to about 6500 rpm.
what could it be???
Old Feb 20, 2008 | 11:32 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: sputtering after like 4500 rpms
run a koeo/koer test ..check for codes..if none.. check secondary ignition components such as car, rotor, wires and plugs
Old Feb 20, 2008 | 11:45 PM
1995mustang818's Avatar
1995mustang818
TFI module maybe ???
Old Feb 21, 2008 | 02:16 AM
lxman1's Avatar
lxman1
Partially clogged fuel filter causing it to lean out under a load @WOT?
Like mentioned, a good tune up wouldn't hurt. Plugs, wires, cap, rotor and fuel and air filters.
What cam is in it? Stock? Weak valve springs perhaps.
Old Feb 21, 2008 | 11:29 AM
stanguy306's Avatar
stanguy306
+1 on the tune up....9 times out of 10 thats your issue with a relatively stock set up....I had the same issue on two of my cars when I bought em....tune up did the trick....you dont want to rev higher than 5100 anywayz...valves probably floating all over the place....ha
CS2007
Jun 25, 2019 09:45 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Sixer4Life
Oct 12, 2015 04:26 AM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
lmurf60
Sep 24, 2015 10:07 PM
