1989 mustang lx fuel pressure
RE: 1989 mustang lx fuel pressure
have the car running,
35 psi stock engine NO MODS
40 psi engine modded lightly,
42-45 psi Head, Cam, Intake, Stock Fuel Pump.
Numbers past 40, makes the ecm use a different strategie and effect the injector's timing to keep the A/F on track within the limits of factory programming.
Depending on your setup, this can make or break you.
If you have a adj reg, have fun and see what fits you best, but dont be suprised if you find a powerfull setting, only to have the ECM fall back on its tables, andif your outside those tables, it WILL do whatever it can to fall back within them.
The A9P and A9L ECM's have better perfomance strategies, than the others, but nothing beats a A/F Guage, and tuning software while on a dyno.
set up
1989 Mustang LX 5.0 Edelbrock Performer 5.0 EFI Intake Msd 6AL MSD blaster coil March Performance under drive pullys a/c ELIMINATOR smog ELIMINATOR cam bbk cold air bbk70mm THROTTLE BODY 73mm mass air ford raceing headers and H pipe 40 flowmasters T 5 TREMEC 373 9' ford rear end [/align]
MEISTERSNFB
03-31-2020 07:50 AM
