long tube headers intstall
is there anyone has installed longtube headers on their 94-95 mustang gt? If so, what were the hard part about putting them in andalso do you have any suggestions.
[/align]
RE: long tube headers intstall
I know its different for a fox but for it I had to loosen the motor mounts and jack the motor up and slide it over a tick to get the passenger side in. The starter was also out. (as well as the tranny during the first install). On the drivers side It just slide up from the bottom. The tranny was out when I did that one also so it literally just slide in.
IF YOU HAVE A LIFT IT WILL MAKE LIFE EASIER . IF NOT JACK THE CAR UP PUT JACK STAND ON EACH SIDE OF THE LOWER ARM OR DRIVE ON RAMPS , PUT STOPPERS ON THE BACK WHELL FOR SAFETY. THEN TAKE OFF THE MOTOR MOUNT NUTAND THEN LOOSEN THE NUTS AND BOLT FROM THE FLANGES. TAKE A 2 BY 4 PUT IT ON YOUR ROLL JACK THEN PUT IT UNDER THE OIL PAN SLOWLY JACK IT UP. THEN YOU CAN GET TO THE HEADER BOLT EASIER AND INSTALL THE HEADER THAT WAY TOO.
Luke9222
10-22-2015 11:55 PM
