Idle Problem
Idle Problem
Okay I have posted before and here we go again. I still have a issue with the idle sticking and sometimes surging when at a light in neutral (manual). I have replaced the IAC, MAF meter and sensor, cleaned the throttle body, verified TPS set to .98, and can't find any vacuum leaks. My SMOG gear is gone so the EGR is out.
I have been told it can be a coolant sensor, MAP sensor and whatever else I forgot by now. [:@]Anybody know where the next best place to start is???
RE: Idle Problem
you can test cross counts of the 02 sensor to see if they're lazy, reading rich, or lean. back probe with a meter and make sure its crossing 450mv. if they're staying high you'r rich, low you're lean. barely crossing 450mv, they're lazy (need new ones)
