fuse help????????
RE: fuse help????????
when does it blow?? when you use the brakes?? if so remove the light assemblies and look for a bad socket/ melted one and or a shorted bulb and or a pinched wire that may have occured when someone put assembly back in
Actually its when I have my brakes on then pops when I push in my clutch?????? I did have a license plate lamp socket that was bad, replaced it, put a new fuse in it, turned the key on, pumped the brakes, turn the on the turn signals, everything was fine. Then with the brake on I pushed in the clutch, thenit popped!!!! Thanks!
jwog666
12-27-2021 08:09 PM
