e-brake problem.
Hey guys,
I went to use my e-brake last night and it wasn't working. I would pull the arm up but it would just go back down. After looking at it for a sec I realized why. If you've ever looked at ur e-brake handle you'll see that the arm stays up because theres a stationary gear at the bottom of the arm and the arm has a hook that grabs the teeth and hooks into them. So as you pull up, the hook hooks into teeth higher and higher up to hold the arm in place. Then when you press the button it releases the hook and lets the arm go back down. However the hook needs something to help it engage and hook onto the teeth. This is done by a littls spring that wraps around the front of the hook and goes into a groove behind the e-brake handle. Does anyone know the spring i'm talking about? Well if so, mine broke. So were can I get a new one?[/align]
ORIGINAL: PRO50SC
You have to buy a complete unit. You can't get just the spring.
Vrooom
Feb 21, 2016 05:25 PM
ccdguy
Sep 19, 2015 05:20 PM
