BIGGEST SHOT?!?!
Old Mar 14, 2008 | 03:55 PM
pony831's Avatar
pony831
Default BIGGEST SHOT?!?!
whats the biggest shot of nitrous a stock 5.0 block can take??
thanx
Old Mar 14, 2008 | 04:58 PM
Hung Like a Stang's Avatar
Hung Like a Stang
Default RE: BIGGEST SHOT?!?!
well thats a very tough question to answer.
If not done correctly, a 100 shot could potentialy ruin your engine from running lean. Things like a Fuel pressure safety switch, and maybe a window switch are nice to have. And you NEED an adequate fuel system depending upon how big of a shot you're running.
A stock block (302, non-mexican) can theoretically handle 500-550 hp. SO, with that, I guess it depends how much power you have now, and how much you'd like to add to it.
There's guys that run 250 shots on a SBF all day long.
Old Mar 14, 2008 | 05:02 PM
Rajun_Cajun's Avatar
Rajun_Cajun
I would say about a 300 shot, possibly a 400...
Old Mar 14, 2008 | 05:55 PM
pony831's Avatar
pony831
cause i was thinking of doing h/c/i swap and then going with a NOS direct port 100 shot
Old Mar 14, 2008 | 05:57 PM
Rajun_Cajun
On a serious note, you could do a 125 wet shot. You just have to watch your timing, a/f ratio, etc.
Old Mar 14, 2008 | 06:08 PM
pony831's Avatar
pony831
cause ive seen a NOSdirect port wet shot for $680 it came with jets for a 35,50,75,100 shot but it said it was capable of a 300 shot with the right jetting....now can i get the kit and slap it on and run a 100 shot on a completely stock engine?or should i wait and do the h/c/i then the nitrous?
thanx!
Old Mar 14, 2008 | 06:16 PM
TRexGAWD's Avatar
TRexGAWD
You could run a 100 shot on a stock block with no problems, as stated before though be careful that you are not running lean. What year is your car?
Old Mar 14, 2008 | 09:44 PM
Forged331's Avatar
Forged331
I typically see people spraying 175 shot wet at the most when stock, and 150 shot dry with a fuel pump upgrade. Not saying I haven't seen a guy spray more and nothing break, but you would be running a risk. Keep in mind nitrous is like heroin...once you shoot it, you want more!!
Old Mar 14, 2008 | 09:53 PM
WhiteWindsor's Avatar
WhiteWindsor
I cant relate to the heroin analogy[8D], but usually if your car is running good, has good compression and not burning excessive oil, a 100 shot will be fine. I dont believe i would push it past that. IMO i would save up for a descent h/c/i and worry about the juice later.
Old Mar 14, 2008 | 11:31 PM
pony831's Avatar
pony831
my car is an 87 gt it runs good so far no problems....h/c/i and the juice are on my to do list lol i was just wondering if i could play with the juice first(safely) then do the h/c/i?
Tivo304
Aug 28, 2023 12:19 PM
Vrooom
Feb 21, 2016 05:25 PM
ccdguy
Sep 19, 2015 05:20 PM
Beerman309
Sep 19, 2015 01:16 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
