Brake Fluid leak
Old 03-24-2008, 02:47 PM
stanguy306
stanguy306's Avatar
Default Brake Fluid leak
Hey Guys, question for ya regarding a small puddle of brake fluid under my car driver side (where you would jack up front of car from) leaking right there. I havent had time to inspect. Just checkin to see if this is common problem. Faulty brake master or?Could aline havecracked? I havent ever had issues with brakes before. Thx!!
stanguy306 is offline
Old 03-24-2008, 03:16 PM
crusin92red5.0
crusin92red5.0's Avatar
Default RE: Brake Fluid leak
you could jack it up from the k-member directly under the car. but mine sits to low to get a jack under there. i always jack it up from just behind the wheel on the frame.if its a master cylinder leak you should be able to diagnose it from up top. probably a hose or caliper leaking. if thebrake fluid is everywhere, clean the area with brake cleaner and then come back to the problema couple days later to see where its leaking from.
crusin92red5.0 is offline
Old 03-24-2008, 05:22 PM
WhiteWindsor
WhiteWindsor's Avatar
Do as said above minus the brake cleaner. I'm **** about my engine bay and brake cleaner can boil the paint, not to mention if it sprays onto the body as well. You should be able to find the leak quickly if it's leaking that much. Have someone to help you so one can push the brake's while the other one is looking for leaks.
WhiteWindsor is offline
Old 03-25-2008, 01:20 PM
crusin92red5.0
if my engine bay looked like yours i'd be **** about it too. but it doesn't.
LivingInThePast
09-16-2015 12:20 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
IronRaptor
09-09-2015 08:10 AM
09-08-2015 11:50 AM
Quick Reply: Brake Fluid leak
