94 GT T56 Swap from AOD-E
Old 03-27-2008, 02:34 PM
Turbosl2
Turbosl2's Avatar
Default 94 GT T56 Swap from AOD-E
I have been trying to figure out what i need to swap a T56 trans into my 94Gt SN95 body that has a 5.0L and a AOD-E auto.
So far i have been told i need the following.
T56 trans with mech speedo pickup (tooth driven) ford racing M-7003H bellhousing included
10.5" Clutch but ford racing says i can run a 11" with the flywheel below and it will fit inside the bellhousing, is this true?
Flywheel (pref billet steel) M-6375-A302
94-04 clutch cable
94-04 Quadrent
94-04 firewall adjuster
94-04 pedal assembly (just purchased on ebay last night)
94-04 Shifter
94-04 Shifter housing/boot
86-93 Clutch fork
Here is what i do not know
I am told i need to shorten the driveshaft, ford racing does not have an exact number on how much to shorten
I have been told i need to modify my crossmember, but i seen a crossmember on D&D performance in a kit but do not want to buy the kit since i can get the trans cheaper and driveshaft done cheaper.
What else can people tell me and what am i missing?
Thanks
Turbosl2 is offline
Old 03-27-2008, 03:15 PM
ewgoetz
ewgoetz's Avatar
Default RE: 94 GT T56 Swap from AOD-E
You try calling D&D up and seeing if they would sell you the crossmemberwith out the kit?
ewgoetz is offline
Old 03-27-2008, 04:00 PM
Turbosl2
Turbosl2's Avatar
not yet. I will most likely try that. First i just want to know what else there is to this swap, especially the driveshaft stuff.
Turbosl2 is offline
Old 03-28-2008, 10:33 AM
Turbosl2
Turbosl2's Avatar
Does anyone have any information for me on this
Turbosl2 is offline
Old 03-28-2008, 02:19 PM
AdderMk2
Banned
AdderMk2's Avatar
D&D sells the whole kit... shortened driveshaft and all
AdderMk2 is offline
Old 03-28-2008, 05:47 PM
deadcarnahans
deadcarnahans's Avatar
It costs less to have a shaft shortened and balanced than to buy a new one.
You can make your own cross member also.
You will need to tune the PCM deleting the AT control functions.
deadcarnahans is offline
Old 03-30-2008, 10:45 AM
Turbosl2
Turbosl2's Avatar
ORIGINAL: deadcarnahans
Exactly my thoughts. I am using tweecer so turning off the AT control functions will not be a problem. Anyone know how much to shorten the driveshaft.
Turbosl2 is offline
Old 03-30-2008, 11:58 AM
94IVGT
94IVGT's Avatar
ORIGINAL: AdderMk2
+1 on d&d's kit. ive got mine here at my house waiting for my new engine.
94IVGT is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: 94 GT T56 Swap from AOD-E
