Cheap Drag wheels?!?
Old Apr 15, 2005 | 01:21 AM
FiveOhNo's Avatar
FiveOhNo
Default Cheap Drag wheels?!?
alright, so i made it out to the dragstrip in the stang tonight...ran a measly 9.54 @ 78mph (1/8th mile...duh)...lost traction through all of first and a good portion of second...so i'm in need of a cheap pair of wide rims i can put some slicks or drag radials on...i was looking for some cragars...but can't seem to find any 4-lug applications...thanks for any help
Old Apr 15, 2005 | 01:48 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: Cheap Drag wheels?!?
Just get a set of 10 holes, they are not the lightest (or best looking) but can be had for almost nothing, the gain from tacktion will be alot more than the weight savings. Otherwise keep checking on ebay.
Old Apr 15, 2005 | 04:15 AM
FiveOhNo's Avatar
FiveOhNo
best place to get em???
Old Apr 15, 2005 | 04:29 AM
primetime5.0's Avatar
primetime5.0
junkyard
Old Apr 15, 2005 | 04:36 AM
FiveOhNo's Avatar
FiveOhNo
eh, almost no time to go to the boneyard......also, will 295's fit in the back?
Old Apr 15, 2005 | 04:39 AM
primetime5.0
may need a wheel spacer and flip the axle damper (quad shock)
Old Apr 15, 2005 | 11:37 AM
JD1969's Avatar
JD1969
ORIGINAL: FiveOhNo
Come on you can't an hour to run to a boneyard? Check around with some of your local Stang guys, guys around here are literally giving them away.
Old Apr 15, 2005 | 05:38 PM
Aliate X's Avatar
Aliate X
I ♥ Acer
ORIGINAL: FiveOhNo
You will DEF need a wheel spacer and yes, flip or remove the quad shock. Just go with 275's they fit with no wheel spacer.
jwog666
Dec 27, 2021 08:09 PM
mungodrums
Sep 28, 2015 10:54 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
