THANKS GUYS!!!!
THANKS GUYS!!!!
After messing with this transmission for the last month or so(it was at the trans shop getting the fox input shaft) I FINALLY got it in. Changing out the pilot bearing to the V8 instead of the 4 cylinder worked wonder. So I just want to tell you guys THANKS for helping me out with all the questions I had, but I do have another question or two.
When I went to put the shifter boot on, the shifter won't go past neutral. When I got this trans it came with a Hurst short throw. So I need a new plastic "surround" piece and shift boot, what do you guys use?
How do you adjust the stops on the shifter? I don't want to get it out tommorow and over shift it and tear this trans up.
I still have to put the trans cross member in and figured I would replace the bushings before I put it back in. I checked Auto Zone and Advanced and they don't have them(Supposedly). Would NAPA carry them?
RE: THANKS GUYS!!!!
to adjust stops back b olts out so you can get a full engaugement then run them in until stops touch then back off a hair and tighten down and run through all gears to make sure shifts are clean and crisp
RE: THANKS GUYS!!!!
Woo Hoo, she finally came out of the garage!!! I got to take it down the road and it was awesome actually having 3rd gear not grind!!! Now its time to get her cleaned up and post some pics. Thanks again guys!!!
RE: THANKS GUYS!!!!
make sure the stops don't KEEP it from fully engaging. b&m is no longer putting the stops in because people are not setting them right, only being in gear partially, and wrecking their trannies
it is to keep you from bending a shift fork when being aggressive...thats it...not just a positive stop, it should'nt touch it on a normal shift
