sputtering?
Old Apr 19, 2008 | 09:01 PM
bigdal94's Avatar
bigdal94
Default sputtering?
so i was driving my car and it all the sudden started sputterin and losing its power. still has some but nothing like it normally does and should. it seems like it wants to run good at times but keeps doing it. sounds different also. seems to be cuttin out pretty bad. any ideas what could be causing this? bad spark plug or wire maybe?
Old Apr 19, 2008 | 10:29 PM
mattwright101's Avatar
mattwright101
Default RE: sputtering?
same problem here
come on 5.0 gurus
Old Apr 20, 2008 | 01:10 AM
Boosted5.slow's Avatar
Boosted5.slow
start off with the basics
Fuel,spark, is there a check engine light on,cap rotor,plugs see if there wet fuel or if there coated in suit,Tons of easy stuff you can do first, but if i had guess check your fuel filter...
Old Apr 20, 2008 | 07:16 AM
Tha Boss's Avatar
Tha Boss
I agree check the usual electric or spark culprits and then check your fuel filter. Depending on what year you have the mass air sensor could be the problem also.
Old Apr 20, 2008 | 08:56 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
how does it idle?? if it idles okay...run a fuel pressure test...may have a weak pump or restricted filter...if it idles rough then run a koer/cylinder balance test
Old Apr 21, 2008 | 04:31 AM
FoxGT's Avatar
FoxGT
Need a little more info before it can be narrowed down to 1 or 2 things. Need to figure out what's causing it to start, if it's related to heat, vibration, ect... but it could be tons of things.
Anyway...
Does it do it all the time now or just sometimes at random?
Does it do it only when the engine has been on for a while?
Does the sputtering stay there if you push the throttle down more?
ShaneB26154
35
Mar 4, 2021 04:05 AM
MEISTERSNFB
Mar 31, 2020 07:50 AM
mustang96gt
Mar 21, 2006 08:10 PM
SGTMack
Feb 7, 2006 04:40 PM
tokinGLX
Jan 8, 2006 11:50 PM
