Rockers came undone help!!!
Hey guys i put new H/C/I on my 5.0 got all done started it and anyways ended up pulling the engine to fix the rear main seal and, 3 studs for the rockers backed out and were like just sitting there but i didnt use and locktite? so im wondering if i retorque them and use loctite will it be ok??? also that would cause water to run into my oil righT?
RE: Rockers came undone help!!!
Yep, the studs should be torqued to around 30-35 lbs. I think, check with machine shop, if they are aluminum then no locktite, cast heads use it ,it won't hurt, actually I use it on most bolt to steel parts, it can only help. Again, if aluminum use anti-sieze in the threads to get correct torque reading.
ORIGINAL: jerod187
no, rockers have nothing to do with coolant
69MustangCoupe393cid
10-03-2015 10:33 AM
JDWalton
09-24-2015 08:47 PM
