Fuel pump going bad?
RE: Fuel pump going bad?
http://content.sears.com/data/produc...337000-dlv.jpg
That is what the tool looks like. You should be able to find them at any parts store and most hardware stores.
ORIGINAL: 1991_5.0_Convertible
How do you tell if you're fuel pump is making noise or going bad? If I go behind my car when it's turned on I can hear a high pitched whining noise, is that it?
I just pulled my 87 GT tank for a very loud original pump, only it wasn't the pump at all. There's a small galvanized anti-slosh sump that surrounds the pump & the solder joints in the tank had broken free and the sump slid up against the pump. When I applied power to the old pump while submersed in a paintcan full of kerosene, it was quiet and had good pressure at the end of a 10 foot 3/8" fuel line. . I still have to get the sump soldered, but I'm thinking that it might be cheaper just to find a 92 or 93 tank in the pick and pull, and check it for rust and security. Has anyone had this problem before?
Far as I know, 87-93 tanks are identical except for the outer shielding (one piece v 2 piece). I wouldn't pass up a good 87 tank, but I figure that 92-93 tanks would generally have less rust than the earlier cars. In a junk yard full of Foxes I'd try the later cars first, although my 87 tank is rust and trash-free.
