Tuning questions
Old 05-17-2008, 07:32 AM
2broke2gofast
2broke2gofast's Avatar
Default Tuning questions
I've got a 95 5.0 with: afr 165's, TFS intake, unknown cam (in it when I bought the car wrecked), 30lb injectors, matching maf, adj fuel pressure reg., 255lph pump, full exhaust, and most of the other bolt on norms. I was dissapointed with the track times I ran with a 9.0 (1/8th) being my best of just 4 passes with a 2.09 sixty foot. I have already made plans with a local shop for a tune, but was curious as to what increases anyone here has seen on cars with similar setups after a custom tune. Any info would be helpful, thanks...
2broke2gofast is offline
Old 05-17-2008, 08:48 AM
nitrous_bob
nitrous_bob's Avatar
Default RE: Tuning questions
well first off, you need tires. every tenth of 60 foot is worth 2 tenths ET(1/4 mile anyways), you should be able to cut a 1.6 sixty right now.
a 9.0 is like a 14 second 1/4
w/ better launch you should run 13.20's , and a tune can get you some amazing results i'm sure, if they tweaked another 40 hp, your in the 12.80 range where u should be
nitrous_bob is offline
Old 05-17-2008, 09:06 AM
2broke2gofast
those times are with nitto dr's, however I didnt have a gauge w/ me when I ran and I ended up w/ 30psi in the tires on my final and best pass.
Old 05-17-2008, 10:05 AM
nitrous_bob
you need to heat them better, and drop to about 20 psi
i've never used nitto's and heard mixed feedback on them. i use nothing but mickey thompson, i have tried just about everything over the last 18 years of playing 5.0's and the only other good tire imo is the hoosier quick time pro. but they are only bias-ply like the regular et street.
i use mickey et street radials and have no probs cutting 1.7's all day long. this year i'll dip into the 1.6's for sure.
Old 05-17-2008, 12:39 PM
2broke2gofast
I agree I need to heat them better my attempts in the bleach box were sad. I blew the tires on into second gear, and now I think the tranny is due for some work, it's a bitch to find third gear on a hard shift....
Old 05-17-2008, 01:59 PM
steele901
steele901's Avatar
ORIGINAL: 2broke2gofast
here's a word of advice from someone whos been in you shoes. DON'T rebuild that T-5 when in goes. start looking for a good tremec tko-500/600. i broke 3rd three times before i sold my 95. hind sight is 20/20 and if i could go back i would for sure have bought a lightly used tko off corral.net or looked for one locally. it would have been WAY cheaper and less of a headache in the long run.
so that being said, once you get that tune, you'll more then likely be making more power then i did so between that and your drag radials you can kiss that T-5 goodbye.
theres my 2 cents, take it for what its worth
that 95gt was such a pain in the ***...but man do i miss that car
steele901 is offline
09-08-2015 06:25 PM
cbird1177711
09-03-2015 08:43 PM
whatsup62
09-03-2015 01:38 PM
cbird1177711
09-02-2015 08:51 PM
09-02-2015 08:40 PM
Quick Reply: Tuning questions
