torque box reinforcement
RE: torque box reinforcement
so you installed the torque box plates first and the battle boxes last? thanks for the info, it will make this job much easier. im going to do the plates right now and the boxes later when i have the cage done. i was afraid that if i did the plates first i would not be able to install the battle boxes.
are you worried about rust getting between the lower plate and the torque box and causing rot?
battle boxes first, then torque plates, then the subframe conn. partial torque plate last... the full torque plate gave a good flat solid mounting area.
rot? there is no higher chance of this rotting than the rest of the car/any car... in fact less of a chance if you prep clean weld clean then protect.. you can use red oxide primer then a gloss black overcoat I am sure there are other tougher paints out there that could be used or you could use undercoating as a last coating?
ORIGINAL: kalash
does anyone have the exact dimension of the battle boxes, and all the other weld on plates? i just got a bunch of steel for from from my old metals teacher way back in highschool. i plan on weldin up some of my own and cutting the plates ect.
blueprint for battle boxes
please e-mail me the upper and lower battle box blueprints to gjndreu114@yahoo.com I highly appriciate it
daltron
04-28-2016 08:10 PM
2005, 50, arms, box, control, cracked, directions, installing, mustang, pic, plates, reinforce, reinforcement, reinforcements, reinforcing, torque
