valve piston clearence!!!!!!!!HELP!!
my friend has a stock bottom end with a z303 he has stock heads all worked to the max,intake an hp carb...........how thick of a head gasket should he get to fix the clearence issue,also hes spraying the car so the whole compression thing shouldnt matter?also whats the max lift you can have in a stock bottom end
