upper intake install
RE: upper intake install
ORIGINAL: 87mustang5.0
my timing is almost all the way retarded... the dist is sittin right on... whats sd mean? im just now started working on mustangs...
When I took mine off the other day (and it's probably the first time it's ever been off), where you have the pcv labeled going, mine was actually the one that goes to the vacuum tree. The two little ones was for the fuel pressure regulator vacuum line and that other smaller line that comes from the passenger side area. My pcv line actually went on the end there where you have "to vacuum connector."
inyadreems
08-21-2015 09:10 AM
