Head Accessories?
What all do i need to get with new heads?
i know i need new gaskets for the head to block, new valve covers and gaskets for those...
but do i need new spark plugs, header gaskets, fasteners, cylinder head dowels, injectors, etc etc?
thank you and sorry for my ignorance =)
ORIGINAL: LesteR723
when i thru my aluminum edelbrocks on i got the graphite head gasket for aluminum heads ( steel core laminate i think) i got autolite 3924's as recomended....re-used dowls and got all new arp head bolts and did the intake with them aswell as headers lol also did scorpion1.6 rockers car felt soo much better then those e7 heads[:'(]
ORIGINAL: mjr46
you will need new plugs cause tfs uses different style and in instructions it'll reccommend type......head bolts=get a good set of arp ones......dowls reuse them from your block.....injectors?? depends on the hp level and rest of your combo..most h/c/i set ups can still use the 19's but when other mods in the future come 24's would really give you a better buffer for proper tune
ORIGINAL: LesteR723
here is everything the car has done:
new radiator, Cold air, mass air, EGR spacer, TB, TF intake manifolds, b303 cam, stage 2 clutch, cobra trans, alum driveshaft, 3.73, pro 5.0 shifter.
im not good at this kinda stuff so you tell me =) haha
