CAR IS HARD TO START..???
Hi I have a 89 Mustang 5.0 and my problem is.. Its hard to start.. I just bought it not to long ago it been all gone thru etc... But inorder to start it at times you have to hold the gass down all the way and it will eventually crank up... What would this problem be? How can I fix it?!
RE: CAR IS HARD TO START..???
i had that problem. did this just start happening? something that they had to fix for emissions fixed my problem. when you start it does it smell like gas or does black smoke come out the tail pipes? does it happen when its warm? does it start fine when its cold?
this is my problems that they fixed.
no reponse from ground controll circuit to egr contoll solenoid.- found out my solenoid was cracked from heat as in air injection controll solenoid.
not enough vacum reaching egr controll valve as secondary air controll valve is also leaking.
repair vacum line to fuel pressure regulator
this is the parts i needed. egr controll solenoid valve, secondary air controll A valve, secondary controll B valve, eec controll power relay.
Soldier GT
12
08-20-2015 09:42 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
