quick question to the knowledgeable people on here.
RE: quick question to the knowledgeable people on here.
ORIGINAL: 561boii
can you take the heads and intake (upper and lower) off of a 347ci and put them on a 302ci???
the 347 uses the same 8.2" deck block as the 302, just has a 3.4" stroke and 5.4" rods instead of the stock 3" stroke and 5.09" rods.
they are the exact same block.
now, a 302 block uses 7/16 head bolts, if the heads are aluminum and are made for a 351 the only difference will be the head bolt holes in the head will be for 1/2 inch bolts, and to use them on the 302 you will need some reducer bushings but thats only if the bolt holes are 1/2".
but you really need to know what heads they are before you try, most inline heads with a 2.02 or bigger intake valve will not clear the stock pistons.
