bouncing speedometer
Old Jul 30, 2008 | 03:46 PM
BayArea5one0's Avatar
BayArea5one0
Default bouncing speedometer
My 1991 GT 5.0 has a bouncing speedometer, especially when the engine is cold. It bounces all around unless at a dead stop. I was advised to check the speed sensor near the trannsmission, so I asked the shop as they are rebuilding mine and they said it shouldn't cause that issue since I have a manual gauge, not electric. Does anyone know what I should look into next? TIA.
Old Jul 30, 2008 | 04:19 PM
tyler72's Avatar
tyler72
Default RE: bouncing speedometer
You need to take out the cable and put some really thin grease on it (the actual cable inside theouter covering)to lubricate it. It works better when hot because the grease is warming up and getting thinner. If you don't do this then just take it out, clean it all up with brake cleaner and then coat the thing in graphite. That usually does the trick.
Old Jul 30, 2008 | 04:29 PM
ewgoetz's Avatar
ewgoetz
The speedo cable can be going bad, the speedo gear going into the trans can be worn, or the gearing in the speedo gears in the speedo it self.
Old Jul 30, 2008 | 05:20 PM
camaroeater's Avatar
camaroeater
My speedometer needle hasn't jumped around since its beenhot, but just started doing it today. I pretty sure mine is the speedo gear behing the cluster b/c on can hear it inside the car...sounds like a scraping noise over and over.
Old Jul 30, 2008 | 07:36 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
if a cable doesn't solve the issue then you'll need a new speedometer ..I've had a few do that and it was the speedo itself
Old Jul 30, 2008 | 09:54 PM
LesteR723's Avatar
LesteR723
maybe you should stop burrying the damn thing lol :-p
Old Aug 4, 2008 | 08:31 PM
BayArea5one0
Thanks everyone for your help!!!
Old Aug 4, 2008 | 09:05 PM
mjr46's Avatar
mjr46
so did you fix it???
msavoia23
12
Jul 7, 2018 12:08 PM
articman
Jun 21, 2018 11:45 PM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Nurdyguy
Aug 21, 2015 10:23 PM
91LXmustang
Dec 27, 2003 11:31 PM
