water pump replace
water pump replace
i got a 88gt stang and im replacing the water pump, but the thing that holds the water pump, i believe its the housing or timeing cover, not sure, needs to be replaced too. i took off the pulley and the screws i believe that need to be taken off (13 screws) and it still wont come off, its a b**ch. any suggestions?
btw, WELCOME ME TO THE FORUMS! XD
RE: water pump replace
I've had to drop the oil pan a little before because sometines the rubber lip seal on the pan that is pushed into the u shapped portion on timing cover holds it up a little
ORIGINAL: mjr46
TfcCDR
09-14-2015 12:08 PM
