Another Speedo Gear Q
I am not having much luck searching so here comes another speedo question:
I just bought a 95 GT with some low miles on it. Make a long story short I have found out that it has a 3.55 gear and the speedo is a little off with the 17 inch wheels. Most of all the odometer reads different also. For every 100 miles I go it reads 110, so for every 1000 miles I go it reads 1100. Is there a way to fix this problem? It is not a major problem by any means but I do a lot of traveling and kinda want to keep these miles as low as possible.
RE: Another Speedo Gear Q
I believe this is the gear for 3.55's
http://www.latemodelrestoration.com/...1&comp=LRS
ORIGINAL: mjr46
Is this vehicle speed sensor any way connected to the cruise control that does not work on my car? Or is my cruise not working a sep. problem.
your cruise may be a seperate issue but does work off a speed signal from drive assembley.......the drive assembley will be on left side of tranny in tailshaft and have an elec connection to it on an sn-95
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
