Rear End Questions
RE: Rear End Questions
it will bolt right in not sure what the plans are for the disc brakes but if you plan to use them you will need a master cylinder and proportion valve. other wise its a direct fit. the drums wont work unless you swap in fox axles because the sn95 axles are longer. good luck with it
ORIGINAL: mjr46
why do you want the cobra rear?? if it's for the disc brake set up..swap that off and on to your fox
swapping the whole rear is quicker
Im doin it for the 5 lug and the disc brake set up.. plus its gonna give me the 308 instead of 273 but thats not the main reason... I want to do the whole thing cause i have the whole thing sittin there for no cost
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
