No start with key
No start with key
ok so i have replaced the starter relay and the ingition switch and it still wont start with the key i was messing with it and i was lookin at it and if i run a wire from the little prong on the starter relay to the white and pink wire that gose to the igition switch it will start the only thing is is that it will turn over with the key in the off pos any help
this is what i have been using
http://www.veryuseful.com/mustang/te...itchWiring.gif
hey man i just got mine fixed kinda, see i ran a wire from the pink and white one to the double side of wires on the black connector on the clutch safety switch. you know how its got two, found out that the pink and white one only sends power when your in crank position and the red and ? on the black connector of the safety switch runs to the top side of the seloniod try and run it to the safety switch connector and see if that works
yeah thats what i did, u will see a red and blue wire on the top of the selonoid, that wire goes to the black connector of the clutch safety switch, run a wire from the white pink one two the saftey clutch connector, i know this isnt the right way to do it but my car cranks lol, im proply going to run a inline fuse and a toggle just to be careful
09-08-2015 11:50 AM
