went to track, dissapointed.
#22
RE: went to track, dissapointed.
not really, just help from flexing. a buddy of mine on www.pittspeed.com with his 00 TA got a best of 1.59 60' with no subs and a best of 1.67 with subs. this is with MT DRs, LCAs, panard bar, springs
#23
I have to agree with ohsoquick02, many times people build a engine combo and things dont match and they end up running slower then faster. Anyways, also the 12 second combo thing is def possible, I know a certain car with stock motor, bolt ons (t.b., mass air, echaust) aod with some stuff and runs 12.8's at 102....the goal of my coupe will be 12's with no power adder, and the stock engine with bolt ons...its easily possible and will be fun doing. And it wont be a drag car, daily drivin street car
#24
for the most part my parts match.
my professional products intake rpm range is from 1500-6000rpm
and my b-303 cams range is from 2800-6000rpm.
I only have 24# injectors because I am going to run my nitrous.
I still have my 73mm maf on,
my rear seal is blown, and it leaked oil all over my clutch, so it slips bad too.
I know my stock throttle body hurts too, but my 70mm was leaking at the throttle shaft, so I had to go back to the stock one.
the cam and intake shows a big improvement in power compared to the stock cam and intake.
#25
yes but youre **** dont match. you have all that rpm but your heads are stock aren they? which have a power peak of like 5k. now your hurting your combo. also that 73mm maf for your 70mm tb is off. you should be 5mm larger then your tb.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
