PA Performance alternator hook up
Old Aug 31, 2008 | 12:20 AM
GT4HUTCH's Avatar
GT4HUTCH
Originally Posted by 50Trippin
The alternator bracket supports only the smog pump and alt. It's made of aluminum and not very heavy. I used a dremel the first time I did the 3G conversion and spent a good hour grinding.... the second time with a 4" electric grinder took about 2 minutes (Careful of the fuel lines, they're pretty close).
If you put the 3G bottom bolt in and move the alternator towards where you will bolt the top and you'll see that it hits, I used a marker and outlined it and ground it away. The second time around we also needed to flatten the bottom of the alternator bracket top bolt hole so it didn't hit the top of the alternator.
Let me know if you need close up pics and i'll get a couple.
Sure i'll i'd like to see the pics
Old Aug 31, 2008 | 12:36 AM
50Trippin's Avatar
50Trippin
I'll post one tomorrow for ya. I have to pop the alternator off and snap a couple pics since I forgot to take some when I put the alternator in.
jwog666
Dec 27, 2021 08:09 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
mungodrums
Sep 28, 2015 10:54 PM
Sep 25, 2015 09:06 AM
